Utilitaires Alternative à TextEdid pour éditer les fichiers gpx
Bon
Ton fichier s'ouvre correctement !
même dans "TextEdit", voir un extrait ci-dessous
Tu n'obtient pas cela chez toi ?
<?xml version="1.0" encoding="UTF-8"?>
<gpx xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.topografix.com/GPX/1/1" xsi:schemaLocation="http://www.topografix.com/GPX/1/1 http://www.topografix.com/GPX/1/1/gpx.xsd http://www.garmin.com/xmlschemas/GpxExtensions/v3 http://www.garmin.com/xmlschemas/GpxExtensionsv3.xsd http://www.garmin.com/xmlschemas/TrackPointExtension/v1 http://www.garmin.com/xmlschemas/TrackPointExtensionv1.xsd http://www.topografix.com/GPX/gpx_style/0/2 http://www.topografix.com/GPX/gpx_style/0/2/gpx_style.xsd" xmlns:gpxtpx="http://www.garmin.com/xmlschemas/TrackPointExtension/v1" xmlns:gpxx="http://www.garmin.com/xmlschemas/GpxExtensions/v3" xmlns:gpx_style="http://www.topografix.com/GPX/gpx_style/0/2" version="1.1" creator="Sports Tracker">
<metadata>
    <name>2020-10-10-A</name>
    <author>
        <name>gpx.studio</name>
        <link href="https://gpx.studio"></link>
    </author>
</metadata>
<trk>
    <type>Cycling</type>
    <trkseg>
    <trkpt lat="43.588163" lon="6.935727">
        <ele>13.7</ele>
        <time>2020-10-10T08:59:48.000Z</time>
        <extensions>
        <gpxtpx:TrackPointExtension>
        <gpxtpx:hr>77</gpxtpx:hr>
        </gpxtpx:TrackPointExtension>
        </extensions>
    </trkpt>
    <trkpt lat="43.588222" lon="6.935802">
        <ele>13.8</ele>
        <time>2020-10-10T08:59:53.000Z</time>
        <extensions>
        </extensions>
    </trkpt>
    <trkpt lat="43.588287" lon="6.935858">
        <ele>14.0</ele>
        <time>2020-10-10T08:59:57.000Z</time>
        <extensions>
        <gpxtpx:hr>75</gpxtpx:hr>
        </extensions>
    </trkpt>
    <trkpt lat="43.588355" lon="6.935897">
        <ele>12.1</ele>
        <time>2020-10-10T09:00:05.000Z</time>
        <extensions>
        </extensions>
    </trkpt>
    <trkpt lat="43.58841" lon="6.93597">
        <ele>11.4</ele>
        <time>2020-10-10T09:00:11.000Z</time>
        <extensions>
        </extensions>
    </trkpt>
    <trkpt lat="43.588503" lon="6.935993">
        <ele>14.1</ele>
        <time>2020-10-10T09:00:15.000Z</time>
        <extensions>
        </extensions>
    </trkpt>
Réactions: Gerapp38
À présent, oui. :)
Depuis que dans "Réglages", j'ai coché affichage en HTML et non pas en texte formaté. Je cherchais l'option dans les menus, je ne risquais pas trouver.
Donc, TextEdit va suffire à mes besoins.
Merci à tous ceux qui se sont mobilisés pour m'aider. :merci::merci::merci:
Réactions: Bicus
Bon, je me suis réjouit trop vite. :(
En dépit des modifications dans "réglages" effectuées hier soir, TextEdit n'affiche plus mes fichiers gpx sous forme code html ce matin.
Pourtant, je coche "Ignorer les commandes de formatage texte" avant d'ouvrir.
Je ne sais pas ce qui se passe chez moi : quels que soient les réglages choisis, j'ai toujours un format texte. :bigtears:
Ci-dessous, ce que j'obtiens avec tes réglages :
Tu peux essayer, dans TextEdit de rétablir les réglages par défaut (bouton en bas de la fenêtre des préférences)
Et ensuite de vider les caches, en faisant un démarrage sans extension (avec la touche majuscule enfoncée).
Voir si cela rétabli ton appli TexEdit !
D'après ça il semblerait que ce soit ton fichier des préférences qui soit défectueux...
Afin de savoir si le problème viens du système ou de tes réglages il faudrait que tu fasses un test.
Essayer depuis une autre session,(à crée si tu n'en à pas) ou sur le compte invité.
TeXShop ne fait pas mieux avec le fichier gpx mais me permet d'obtenir une copie html.
Celle-ci s'ouvre avec le même TeXShop qui me permet de la basculer en en XML. J'ai des couleurs (très intéressant) mais pas de disposition en blocs avec indentations.
J'ai depuis un certain temps (dernière mise à jour OSX) de petits dysfonctionnements, notamment en ce qui concerne l'affichage des fonds d'écran (exposé sur ce site : macOS Ventura Réglages Système > Fonds d’écran : dysfonctionnements), qui seraient dus à des bugs de Ventura.
Un collègues administrateur m'a dit d'attendre Sonoma.
Se pourrait-il que mon problème ici débattu soit un autre bug de l'OSX 13.5.2 ?
Je ne pense pas, mais !
As -tu testé dans une autre session, dans un contexte propre, ça permettra de savoir si le problème viens de ta session ou du système.
En fonction du résultat, tu pourras soit chercher dans ta session (dans les préférences,caches etc..) soit réinstaller le système par dessus le tien ce qui ne touche en rien à tes fichiers.
